[Browser] How to move the Sort icon to the top right toolbar?
hue
Post by hue »
On previous XnView version, the Sort button was on the top right. Is it possible to move the Sort button from bottom to the top right?
Re: [Browser] How to move the Sort icon to the top right toolbar?
you cannot move buttons, but can switch to old, single toolbar look
change in xnview.ini:
littleBarVersion=2
hue
Post by hue »
Thanks!
GingerNut
Post by GingerNut »
Why not just put it back or make the bar editable?
Yours Roy
Franky
Post by Franky »
You can change the toolbar by right click and add this icon.
FKCapitalism2
Post by FKCapitalism2 »
user0 wrote: Sun Jun 01, 2025 8:38 am you cannot move buttons, but can switch to old, single toolbar look
littleBarVersion=2
v.1.9.2 switched it yet again is there way to return same layout as prior versions?
FKCapitalism2 wrote: Thu Jun 12, 2025 3:51 pm is there way to return same layout as prior versions?
check Layout combobox in Settings > Browser > Toolbar
FKCapitalism2
user0 wrote: Thu Jun 12, 2025 4:04 pm
Great that worked.
