Questions to specific *.mng images
herb
Post by herb »
Hello Pierre,
I use NConvert 7.221_unicode on my Windows 10 system
I have 2 *.mng images which will not be converted into jpg format.
The command which my application uses
nconvert.exe -ignore_errors -page 0 -overwrite -out jpeg -q 100 -o <out-image> <image>
(1)
For attached image australia1.mng I get the error
This picture cannot be written using this format
(2)
For attached image pnglogo.mng I get
Don't know how to read this picture
Do I need additional or other options for conversion into jpg?
Thanks for your help in advance
Best regards
herb
test.7z
(253.43 KiB) Downloaded 8 times
SAMSAM
Re: Questions to specific *.mng images
Post by SAMSAM »
Try, via the -xall command to Tif format (it worked for me). It really didn't work in JPG format :(
