1.9.0 - Browser scroll resets after applying quick filter
moropus
Post by moropus »
XnView: MP 1.9.0 - 64 bit
OS: Windows 10 64bit
This thing bugs me a lot, since I usually have dozens of images in one folder and I need to filter, search and catalog it quickly.
And usually I need to filter something and then look what's around a particular image. But Browser lefts me nowhere and deselects what I have found.
1. Add multiple images to folder in order to show scrollbar (for instance, 100 jpgs and 100 pngs named from 1 to 100)
2. Type jpg to quick filter
4. Click X in quick filter
Actual behaviour (bug):
5. Scroll in the main panel jumps to the top
Expected behaviour:
5. Scroll in the main panel is where the selected image is.
The workaround is to hit Enter to go to the View and hit Enter again to return to the Browser, then scroll shows the actual position of the selected image.
Re: 1.9.0 - Browser scroll resets after applying quick filter
:bugconfirmed:
