1.9.0 - AND/OR quick filters work differently
XnView: MP 1.8.8-1.9.0 64 bit
OS: Windows 64bit
I use quick filters to sort my photos a lot.
I noticed that adding + (and) and | (or) to filters works differently and inconsistently:
* no partial match with +
* no mixing different search sources like category and name
1. Click Quick filter menu, select Search in Categories
2. Add multiple categories, eg "Cats" and "Dogs"
4. Assign categories:
5. Search "cat+dog" in quick filter
Actual behaviour (bug): Nothing is found
Expected behaviour: image3.jpg is found
When I search "cat" or "cat|dog" (part of the category) I've got all the results I expect, but + filter doesn't respect partial match.
6. Search "cats+png"
Expected behaviour: image1.png is found
When I search "png" or "cats|png" (category with extension) I've got all the results I expect, but + filter doesn't work with different search sources.
OS: Windows 64bit
Re: 1.9.0 - AND/OR quick filters work differently
I've tried and it works correctly. 'Categories (catalog)' is enabled?
Screenshots:xnview wrote: Tue May 27, 2025 8:12 am I've tried and it works correctly. 'Categories (catalog)' is enabled?
1. 'Categories' option is enabled.
2. I search 'кот' and find jpg with two categories
3. I search 'кот+jpg' (category and format) and find nothing
4. I search 'кот+пес' (two categories) and find nothing
- Attachments
- 2025-05-27_10-17-54.png (60.66 KiB) Viewed 501 times
- 2025-05-27_10-17-41.png (60.67 KiB) Viewed 501 times
- 2025-05-27_10-17-29.jpg (327 KiB) Viewed 501 times
- 2025-05-27_10-15-32.png (13.2 KiB) Viewed 501 times
please send us some samples files to reproduce?
Here you go.
Categories are embedded into image.
- Attachments
- 1B9A4176_1_small.jpg (106.93 KiB) Viewed 481 times
This problem is supposed to be fixed in XnView MP 1.9.1. Please check and confirm the bug fix here.
Partially fixed (1.9.1 x64, Windows 10 x64).xnview wrote: Wed May 28, 2025 11:54 am This problem is supposed to be fixed in XnView MP 1.9.1. Please check and confirm the bug fix here.
Filter with two categories 'кот+пес' now works as intended.
Filter category and format 'кот+jpg' still finds nothing.
It surely is not.
But I find it extremely useful to search by multiple properties at the same time, since 'кот|jpg' works with category and format/name.
Eg I usually search for images with specific subject (category) which I have already edited (format jpg, not raw).
Checked, and it doesn't work.
ok im wrong, currently + can only be used on categories
what kind of search is it
maybe add/use 'simple search' by default (with simple wildcards * ? )
Browser - quick filter - improve search settings
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
