XnView: MP 1.9.0, 1.8.8 - 64 bit
OS: Windows 64bit, UI scale 100%
Cosmetic bug.
Tab panel has different height when it has single or multiple tabs.
Reproduced both with top and bottom tab align.
1. Click menu View -> Tab -> Show
2. Open image
3. Click Enter to open Browser
4. Close any tab, so single one remains
Actual behaviour (bug):
5. Tab panel resizes by 1-2 pixels. Bottom UI moves a bit.
Expected behaviour:
5. Tab panel size remains the same
1.9.0 - Cosmetic: tab panel different height
- Attachments
- 2025-05-26_15-43-53.png (10.94 KiB) Viewed 121 times
- 2025-05-26_15-43-44.png (12.42 KiB) Viewed 121 times
Re: 1.9.0 - Cosmetic: tab panel different height
I think, you misunderstood.
I see, that current selected tab is higher than deselected, it's ok.
But the whole tab panel shrinks when I close tabs, and that's bug imo.
Here there are both screenshots aligned by window header
- Attachments
- 2025-05-26_15-43-44_aligned.png (11.59 KiB) Viewed 99 times
yes right, but i'm not able to fix the margin when only 1 tab
