XnView MP 1.9.0
XnView MP 1.9.0
You can download XnView MP 1.9.0 here:
Windows x64 ZIP version SHA256: C76630A61D090D9AEDD78B8961ACBA9C1236419220D1889EFF736CBD03258806
Windows x64 SETUP version SHA256: 42FA88644A8BE6141FBD6201532A23CD4C9208441C43D7E3F0AA1EA4CEB8D1B9
Mac x64 DMG version SHA256: 7D0417CEC442F3E46A7FE4E87CEA95AAACA71AFEEA0B7B59FF069E3DD85EC525
Linux x64 TGZ version SHA256: 0751E57813641903D0B99E9FC06FC7CAECD9F62424B3D1DB742E5B42983DCAE7
Linux x64 DEB version SHA256: 92A85F8C147D38C0380D66F1C157859C065CB30E944AF6A9626AF3BD77C3901E
ARM version: https://download.xnview.com/XnViewMP-linux-arm.tgz https://download.xnview.com/XnViewMP-li ... _armhf.deb
Linux x64 AppImages version: https://download.xnview.com/XnView_MP.g ... 4.AppImage
Linux Flatpak version: https://flathub.org/apps/details/com.xnview.XnViewMP
Changelog 1.9.0:
3646: [New] Print all opened images
3642: [New] LibHeif 1.19.8
3641: [New] Thumbnails - split overlay icons - viewtopic.php?t=46432
3640: [New] Print as grayscale
3601: [New] Thumbnails toolbar - split into 2 toolbars - viewtopic.php?t=48717
3587: [New] Windows - Settings - Integration - ProgramData - viewtopic.php?t=31574
3650: [Bug] Items renaming - Shift+Tab - viewtopic.php?t=49051
3649: [Bug] Remove unused caterogies - categories set not cleaned
3648: [Bug] Saving rating label into sidecar and main file - viewtopic.php?t=47238
3647: [Bug] Thumbnails - problems to select with keys - viewtopic.php?t=41636
3645: [Bug] Linux - PDF with GS 9.x - viewtopic.php?t=49052
3644: [Bug] Browser - Category Sets - Assigned, Suggested - improve update trigger - viewtopic.php?t=48478
3643: [Bug] Print - windows scale affects text - viewtopic.php?t=44206
3639: [Bug] Wrong open first image - viewtopic.php?t=49030
3638: [Bug] Cannot write GPS coordinates to JPEG XL - viewtopic.php?t=49022
3637: [Bug] Theme - switching - background of active tab remains unchanged - viewtopic.php?t=49032
3636: [Bug] Resize dialog - 99999 limit - viewtopic.php?t=49012
3635: [Bug] Browser - statusbar/filelist - heic - incorrect BPP info - viewtopic.php?t=49020
3634: [Bug] AI format - viewtopic.php?t=49016
3633: [Bug] Viewer - statusbar - cursor XY coordinates not updating - viewtopic.php?t=47634
3632: [Bug] Rating icon covered by scroll bar - viewtopic.php?t=49007
3631: [Bug] Search - IPTC all fields - viewtopic.php?t=49015
3630: [Bug] Open With - path editable, but has no effect - viewtopic.php?t=49010
3629: [Bug] Titlebar does not remember View setting - viewtopic.php?t=48988
3628: [Bug] Export - focus - viewtopic.php?t=49028
3627: [Bug] Cadsofttools CS_CGM - viewtopic.php?t=49000
3626: [Bug] General - image scaling - improve consistency - viewtopic.php?t=47986
3625: [Bug] Typo in registry setting - viewtopic.php?t=48999
3624: [Bug] Multi-image AVIF - viewtopic.php?t=46613
3623: [Bug] Browser/viewer - shortcut to raw renders differently - viewtopic.php?t=48227
3622: [Bug] Category - category sets - hide assigned categories
3621: [Bug] Browser - thumbnails - shadow threshold - viewtopic.php?t=48367
3620: [Bug] DICOM - viewtopic.php?t=48759
3619: [Bug] Settings - catalog - get thumbnail size issue - viewtopic.php?t=48879
3618: [Bug] Browser - views - thumbnails+details - few issues - viewtopic.php?t=48842
3617: [Bug] Filelist - shortcut - cannot load file shown in subfolder - viewtopic.php?t=48500
3616: [Bug] Browser - categories - 'Hide assigned categories' has no effect - viewtopic.php?t=48479
3615: [Bug] Fullscreen on browser with second screen - some issues - viewtopic.php?t=47899
3614: [Bug] SubSecTime place holder
3613: [Bug] JXL - bad thumbnail - viewtopic.php?t=47723
3612: [Bug] Browser - filelist - details view - pasted file opens in new instance - viewtopic.php?t=47877
3611: [Bug] Archive - not opened in default app - viewtopic.php?t=45759
3610: [Bug] Tabs not hidden after restart - viewtopic.php?t=47965
3609: [Bug] Folder view - rename long name - viewtopic.php?t=46758
3608: [Bug] Rotate - 'Auto crop' crops too much - viewtopic.php?t=46843
3607: [Bug] Edit XMP - IPTC must not be writtent if empty - viewtopic.php?t=42361
3606: [Bug] Face tag - crash on image shortcut - viewtopic.php?t=47205
3605: [Bug] Drag drop issue - viewtopic.php?t=47153
3604: [Bug] MacOS - toolbar command - viewtopic.php?t=48930
3603: [Bug] Info - blinking on file change - viewtopic.php?t=48705
3602: [Bug] Export - file formats - viewtopic.php?t=48832
3600: [Bug] Change timestamp - show files when error - viewtopic.php?t=48771
3599: [Bug] Browser - Categories - clean up menu - viewtopic.php?t=48867
3598: [Bug] Metadata - edit xmp - update rating appearance - viewtopic.php?t=48401
3597: [Bug] Linux - folder tree - many folders shown in root
3596: [Bug] Screenshot - save - titlebar not changed - viewtopic.php?t=48936
3595: [Bug] OpenSSL 3.0.16
3594: [Bug] Edit XMP - save template - keywords not saved
3593: [Bug] Import fails - viewtopic.php?t=48798
3592: [Bug] Linux - open with - extra blank parameter - viewtopic.php?t=48955
3591: [Bug] Edit XMP - Subjectcode not correclty written
3590: [Bug] User theme
3589: [Bug] OpenRaster plugin - viewtopic.php?t=48858
3588: [Bug] App UI - menu structure - View - improve channel commands - viewtopic.php?f=60&t=47439
3586: [Bug] Settings - paths - improve grouping - viewtopic.php?t=47234
3585: [New] Setting to show info treeview header
3584: [Bug] Search similar - viewtopic.php?t=48850
