Search image categories
alee001
Post by alee001 »
Some images may have been tagged with categories, but there is no way to search for them. It is recommended to add a category search function so that unknown or known categories can be filtered out.
Thank you for your attention
Franky
Re: Search image categories
Post by Franky »
There is the catalog filter that allows you to filter by categories.
It's in View/Panels/Catalog Filter
alee001
Post by alee001 »
Franky wrote: Fri May 23, 2025 8:27 am There is the catalog filter that allows you to filter by categories.
Some images are categorized by others. If you don’t open the folder, you won’t know its settings. It is recommended to search for all category tags (even those created by others).
use Advanced search (Ctrl+Shift+F) to search in unindexed files
condition:
- All fields, contains, YOUR_KEYWORD
separate 'All fields' conditions for XMP, IPTC or EXIF are also available
alee001
Post by alee001 »
user0 wrote: Sat May 24, 2025 8:18 am use Advanced search (Ctrl+Shift+F) to search in unindexed files
condition:
But XnView MP does not have this function, and you cannot find out the category of other people's pictures without opening them.
alee001 wrote: Mon May 26, 2025 6:29 am But XnView MP does not have this function
open Browser tab
alee001
Post by alee001 »
user0 wrote: Mon May 26, 2025 7:06 am
open Browser tab
There is only Ctrl+F, not Ctrl+Shift+F, and there is no way to search for categories created by others.
