XnView: MP 1.8.8 - 64 bit
OS: Windows 10 64bit
Can't assign both parent and child category from Catalog Filter.
Can't filter photos from Categories panel.
So I need to use two almost identical panels to catalog my photos for some reason.
1. Check Settings -> Metadata -> Automatically assign parent category
2. Create new ParentCategory and child SubCategory
3. Select image
4. Open context menu, click Metadata -> Set Category -> ParentCategory -> SubCategory
5. Open Categories panel, see that both ParentCategory and SubCategory are checked for the image
6. Uncheck both categories
7. Click on SubCategory in Categories panel
8. See that both ParentCategory and SubCategory are checked for the image
9. Uncheck both categories
10. Open Catalog Filter panel
11. Drag-n-drop the image to SubCategory
Actual behaviour (bug):
12. Image is assigned to child SubCategory alone
Expected behaviour:
12. Image is assigned to both ParentCategory and SubCategory, as in other interfaces
1.8.8: Parent category is not assigned from Catalog filter
Re: 1.8.8: Parent category is not assigned from Catalog filter
To automatically assign the parents categories there is an option in Settings/Metada/Categories and keywords
So the bug is that this option doesn't work in one caseFranky wrote: Fri May 23, 2025 8:41 am To automatically assign the parents categories there is an option in Settings/Metada/Categories and keywords
I had never done Drag and Drop to assign a category.
Indeed, in this way only the child's category is assigned.
right
when you drag a file to category filter panel
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
Fixed in 1.9.2, thank you!
