Product has slowed down dramatically
hfig5297
Post by hfig5297 »
HI, since the last two updates, the product seems to have drastically slowed down.
I use to be able to keep 4 or 5 XnView open and move between then screens and folders with ease, now it can take as long a 30 to 45 sec .
The drive on which the files are access shows no lag time at all if using file explorer, any suggestions ?
Re: Product has slowed down dramatically
please describe where do you have slow down
hfig5297
Post by hfig5297 »
Hi Thanks for the help
As stated i could have had 4 to 5 XnViews open at one time. Now that is not possible as moving file or opening them takes longer than 45 sec. I then tried to use the program with just one XnView open, but that as well seemed to lock up and take more than a minute to clear . Looking at the task manager it using a lot of memory 8,464,3 MB, my installed ram is 16 GB using Windows 11.
hfig5297 wrote: Thu May 15, 2025 11:49 am ... I could have had 4 to 5 XnViews open at one time.
Separate instances of XnView MP ((ZIP versions?), or tabs open in a single XnView MP instance??
Do you have a lot of opened tabs?
hfig5297
Post by hfig5297 »
thank you, I was not aware of the tabs on top. They were extensive, and closing them all out cleared up the problem. Very much appreciated, thank you
