Category list is empty
Frequently Asked Questions regarding XnView (including Answers)
ISSUE
By default, XnViewMP saves all user-modified metadata to Catalog (unless its explicitly 'written').
XnViewMP will not be able to associate saved metadata with files in a new location if you move files using an external file manager,
eg you moved:
  • from
    D:/Photos_OLD/2024/2402/240219_event_name/
  • to
    E:/Photos_NEW/2024/2402/240219_event_name/
and app does not show your Tags/Rating/Labels/Categories(Keywords)
SOLUTION
It's required to fix paths in database.
A - one by one
0. prerequisites
  • make backup of your XnView.db
  • rename current root folder with your images (eg Photos_NEW to Photos_NEW1) and do not open any image inside with XnView.
    You need to make sure that XnView has not indexed this new location.
1. goto Settings > Catalog
  • select single folder
2. press Relocate button
  • update new Path (Note: its are case sensitive)
  • press OK
B - batch processing
0. prerequisites
1. open XnView.db in db tool
2. (optional) open Browse Data tab
  • select Folders table
  • check pathnames (you can edit them one by one, but its slow)
3. Execute SQL query
  • open Execute SQL tab
  • paste query
    NOTE: use Slash and not Backslash, paths are case sensitive
    UPDATE Folders
    SET Pathname = REPLACE(Pathname, 'D:/Photos_OLD', 'E:/Photos_NEW1')
    WHERE Pathname LIKE 'D:/Photos_OLD%';
  • press Ctrl+Enter
4. Write changes to db
  • press Ctrl+S
