1.8.1-1.8.8: windows taskbar ABOVE xnview in fullscreen with StartAllBack
Raider
Post by Raider »
XnView: MP 1.8.1-1.8.8 64 bit
OS: Windows 11 64bit 24H2 26100.3775
additional software: StartAllBack 3.9.8
starting with version 1.8.1 XNview in full-screen mode does not hide the windows taskbar - it remains on top of xnview. After checking old versions I found that there is no such behavior on 1.8.0, but on 1.8.1 it appeared and did not disappear in the newest 1.8.8
this happens with StartAllBack enabled, if you turn this thing off, everything returns to normal
Effect: reduced the visible area of ​​the picture in full screen
1. Just open picture in full screen
Actual behaviour (bug): XNview in full-screen mode does not hide the windows taskbar :bug:
Expected behaviour: XNview hides Windows taskbar in full screen mode
xnview.ini.zip
my settings
(36.01 KiB) Downloaded 16 times
behavior of versions 1.8.1+
behavior of version 1.8.0
Re: 1.8.1-1.8.8: windows taskbar ABOVE xnview in fullscreen with StartAllBack
It seems that StartAllBack force taskbar
Raider
Post by Raider »
yes, but only with new versions of xnview
Raider wrote: Thu May 15, 2025 10:21 pm yes, but only with new versions of xnview
when using 1.8.0, you have not this problem?
Raider
Post by Raider »
xnview wrote: Fri May 16, 2025 6:55 am
sure, I don't have this problem in versions below 1.8.1 (including 1.8.0) as i wrote earlier
i've installed StartAllBack on Win11 pro, and can't reproduce :(
Raider
Post by Raider »
xnview wrote: Thu May 22, 2025 9:53 am i've installed StartAllBack on Win11 pro, and can't reproduce :(
hm-hm!
seems my description is not precise enough. In the startallback settings I have line 3 on the left selected, and on the right - "use the proprietary panel" (sorry, I don't know if this is enabled by default - I thought it was)
if it doesn't work out - then sorry for bothering you, I have a lot of programs and a lot of settings, apparently something conflicts with startAllBack which conflicts with XNview.
i've tried with same, but no problem
