1.8.8 - viewer - png - alpha transparency - clipboard issues
XnViewMP 1.8.8 64bit
Viewer - png - alpha transparency
few issues with copy/pasting from clipboard
0. prerequisites
- have 2 test images (32bit png)
test_img_copy_paste.zip
(1.81 KiB) Downloaded 251 times
issue A
1. open 1.png in Viewer
2. press Ctrl+C, Ctrl+V
image will be pasted, but with halo on borders/partially transparent parts (similar issue)
expected behavior
eg like in mspaint/photoshop
issue B
1. open 1.png in Viewer(instance A) and 2.png in another Viewer(instance B)
2. copy 2.png to clipboard (via Ctrl+C or Ctrl+Shift+C) and insert into 1.png (Ctrl+V)
image will be pasted with artifacts (issue A)
3. press Ctrl+Z to undo pasting
4. close instance B
5. paste 2.png from clipboard into 1.png again
result will be different (it looks like 2.png lost alpha channel on app close)
Related
