If I open a multipage file in XnView, I always see the first page, but do not know how move to the next pages?
Probably a standard situation, but I didn't find a post regarding the in the support are here.
Best regards
Hans
How to display multi-page files in XnView
Re: How to display multi-page files in XnView
On the toolbar, immediately to the right of the two blue arrows which select the previous and next file, you should have two smaller outline arrows which can be used to step through the pages of a multipage.
Yes, I see them, but they are just grey and have no effect.
I've just loaded a multipage test file and had a look, and those arrows should become coloured as you step through the pages.
Note that if you plan to edit the images in a multipage file, it is necessary to save the changes made to a page before stepping to another page, otherwise the changes made will be lost; when a multipage file has many pages resaving the whole file can be slow.
My test file attached.
Hi @cday
- Thank You for the example file. Yes, that works for me also as You described.
- So I guess, I have to specify my description of the problem: It seems the problem is not multi-page in general but multi-page in pdf file-format. And I found, that in many cases XnView seems to be unable to open a pdf-file at all.
hhans wrote: Mon May 12, 2025 4:55 pm Thank you for the example file. Yes, that works for me also as you described.
So I guess, I have to specify my description of the problem: It seems the problem is not multi-page files in general, but multi-page in pdf file format.
Are you able to post an example multipage PDF file that can't be opened?
Problems opening PDF files are generally related to the required third-party software Ghostcript, but if some PDFs open that seems unlikely in this case: again, can you post an example file?And I found, that in many cases XnView seems to be unable to open a pdf-file at all.
Please find attached a 2 pages file, which cannot be opened with XnView.
May be I had to follow Your point with the Ghostscript idea?? What do I have to do?
Confirmed that the provided file, which opens normally in multiple other PDF software's, doesn't open in XnView MP...
Over the years there have occasionally been other PDF files which inexplicably can't be opened in XnView software, so I am starting a new bug thread for that. TBD
