Hot folder recursive mode doesn't support spaces in file or folder names and n sub folders doesn't work' [BUG]
Barthoum
Post by Barthoum »
Hello I encounter some problems using hot folders recursive conversion
After many tests, it seems that the recursive system doesn't support subsequent subfolders...
Is it normal, or will a patch fix that?
The recursvity is clearly limited
PS, if you can add a tip / exemple to set the extension that would be great
or jpg png
with space , or ; to separate values
Re: Hot folder recursive mode doesn't support spaces in file or folder names and n sub folders doesn't work' [BUG]
Please describe how to reproduce
