Set focus to "Export..." button in Export dialog
bohning
Post by bohning »
It would be helpful and speed up my process if the "Export..." button in the Export dialog had the focus so I can just hit Enter to confirm.
Re: Set focus to "Export..." button in Export dialog
bohning
Post by bohning »
Thanks a lot for the quick "fix"!
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
bohning
Post by bohning »
Today I tested this and indeed the "Export" button is now highlighted (blue instead of dark grey on my Mac), but hitting Enter to confirm does nothing. So somehow it doesn't seem to have the default focus, is that possible?
reopened
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
