Show one not four thumbnails on all folders
audiotruth
Post by audiotruth »
In my browser, every folder has 4 tiny thumbnails on it. I can't find a setting to change it to just one large thumbnail. I looked for an answer, but that particular option doesn't show up in Tools > Settings > Thumbnails > Misc. There is no Misc in there.
Using XnView MP 1.8.8.
Re: Show one not four thumbnails on all folders
Settings>Thumbnail - Show 4 thumbnails
audiotruth
showing 4 thumbnails on each folder
OK, so I found the setting that theoretically turns off the "show 4 thumbnails" thing..... but oddly, it still shows 4 thumbnails on all the folders. The setting does nothing. Any ideas?
Running v. 1.8.8 64bit
masterjp
Re: showing 4 thumbnails on each folder
Post by masterjp »
I had this problem, too.
If you active the 4 thumbnails in settings and browse your folders, XnViewMP will create 4 thumbnails for every folder and save them in the thumbnail cache. If you then switch to 1 thumbnail for folders, XnViewMP will use the already saved thumbnails from cache and will show you 4 thumbnails for the folders again! You will change this behaviour, if you completly delete your whole cache. If you already have browsed your whole picture archive, then there is an easier way to change it. You can mark the folders with 4 thumbnails and rebuild the thumbnails. You must open the view menu and choose rebuild thumbnails.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
audiotruth wrote: Sat May 10, 2025 8:47 pm it still shows 4 thumbnails on all the folders.
press 'Rebuild thumbnails' button in Settings > Catalog
