Hello
Not sure if that topic been discussed somewhere but my searches were not bringing back any answer about it so...
I made a bad choice when a pop up window offered me to choose if i wanted to keep the currently opened tabs when I exit the application.
So I was trying tofind a way to correct my mistake...
After a search, I finally found out in the xnview.ini file an entry called :
sessionFlag=1
which was the setting to Keep the tabs.
after changing it to 0, I tried top re open and close the application and the pop up went back on screen so I could change my mistake to ask the app to close all the Tabs.
Then checking the entry showed it with value : 2.
Of course if you read this and try to do such change make sure your application is closed before modifying that .ini file.
Suggestion :
Maybe adding it to the Setting might help...
Hope it helps.
Rgds
Option to close all Tabs when Closing application (or not)
Re: Option to close all Tabs when Closing application (or not)
Isn't there already an option somewhere in Tools > Settings... to enable/disable closing tabs when the application is closed?
Hello
It was my point, I was unable to see it anywhere.
Feel free to point me to it.
I may have missed it.
Rgds
Rgds
Someone familiar with the ever-evolving settings?Omens wrote: Tue May 06, 2025 9:12 am It was my point, I was unable to see it anywhere.
Settings - General - Save session on program exit
Ohhh Ok, now I understand why I did not saw it...
