1.8.8 - browser - statusbar/filelist - heic - incorrect BPP info
XnViewMP 1.8.8 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser - statusbar/filelist - heic
bit per pixel is incorrect for some HEIC files
to reproduce
1. have some sample HEIC file(s) in folder
2. open folder in Browser
3. change Filelist view to Details
4. select file and check Properties column and Properties field in Statusbar
in statusbar - bpp = 0
in column - colors counter = 1
Note: reproducibility is not 100%, same HEIC files may show correct info one folder and incorrect in other
Related
Re: 1.8.8 - browser - statusbar/filelist - heic - incorrect BPP info
i'm not able to reproduce. And if you try 'update catalog from files'?
'Update catalog from files' has no effect, Catalog can be disabled
try to
- open files from different location
- start app with different 'View as' modes (eg Details/Thumbnails+any)
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
fixed in 190
