Batch convert resize action does not calculate dimensions while keeping aspect ratio
brazenvoid
Post by brazenvoid »
This is inconsistency in comparison to the regular resize dialogue. Essentially adding resize as an action of batch convert does not dynamically calculate the other dimension size when changing the other.
I just tried resizing a set of images to a specified width of 720 pixels, and initiated batch. What instead happened was that all images turned out to have 32 pixels as width for no explicable reason.
Re: Batch convert resize action does not calculate dimensions while keeping aspect ratio
this action is applied to a list of image files, so dimensions can't be updated in the panel
