1.8.8: Navigation follows old sort order after refresh
EDW9700
Post by EDW9700 »
XnView MP 1.8.8 64 bit
OS: Windows 64bit
When renaming a file in the browser + refreshing + opening an image + left/right arrow, the previous/next image of the old sort order appears.
Effect: wrong image shown.
1. rename a file in the browser
2. refresh (F5)
3. open (return)
4. next image (right arrow)
Actual behaviour (bug): image following the old sorting appears
Expected behaviour: image following the new sorting appears
Workaround: clicking on the next image in the browser + return opens the correct next image. After that the new sort order is followed.
Re: 1.8.8: Navigation follows old sort order after refresh
do you have same problem when 'settings>View>Misc - Read one image ahead' is disabled?
EDW9700
Post by EDW9700 »
Then there is no problem. Is it intended that way (as default setting when installing) ?
EDW9700 wrote: Fri May 30, 2025 4:31 am To reproduce:
you have a tab already opened?
This problem is supposed to be fixed in XnView MP 1.9.2. Please check and confirm the bug fix here.
