Question to NConvert 7.221
herb
Post by herb »
Hello Pierre,
I am working on my Windows 10 system with NConvert version 7.192
You released this version because of post "Question to NConvert and Windows Short-Filenames". Please see viewtopic.php?t=47413
By accident I found a version 7.221 on your internet-site https://www.xnview.com/de/nconvert/
I thought this is a successor of unicode-version 7.192
But I have lots of problems with this new version using the testfile used for version 7.192
I get very often: 0 files opened / 0 file written
Is this a misunderstanding on my side?
Best regards
herb
Re: Question to NConvert 7.221
do you use the 7.221 unicode? how to reproduce?
herb
Post by herb »
Hello Pierre,
thanks for your quick reply.
This is difficult to answer for me:
On site https://www.xnview.com/de/nconvert/ I downloaded NConvert for Windows 64-bit. The filename is NConvert-win64.zip.
In properties of the contained *.exe file I only see FileChanged on 28.3.2025.
In DOS-box the command: nconvert.exe gives:
 ** NCONVERT v7.221 (c) 1991-2025 Pierre-E Gougelet (Mar 28 2025/08:37:57) **
        Version for Windows 7/8/10/11 x64  (All rights reserved)
** This is freeware software (for non-commercial use)
In forum: Board index -> XnView Family -> NConvert I only see NCovert 1.192
Best regards
herb
you have it here
herb
Post by herb »
Hello Pierre,
thanks for the file. You are great.
A short quickcheck showed: all is running fine.
I will remember the address in order to find - next time - the correct file myself.
Thanks again.
Best regards
herb
