Version: 1.105.0
OS: [window10]
The 'Add files'and'Add folder' in input tab ignores the last used path. It always opens the same fixed folder ([The specific fixed path]).
* Tried: Running as Admin, checked xnconvert.ini in appdata\roaming(not read-only), reset xnconvert.ini. Nothing works. The list_folder value doesn't seem to save/load correctly.But I can change the list_folder value manually.
'Add files'and'Add folder' ignores last path
Re: 'Add files'and'Add folder' ignores last path
I've tried and it works, list_folder is updated. Where is your settings?
xnconvert.ini in AppData\Roaming\XnConvertxnview wrote: Fri Apr 25, 2025 1:47 pm I've tried and it works, list_folder is updated. Where is your settings?
i know what happened.The 'Add files' can remember the last path but 'Add folder' can't.xnview wrote: Fri Apr 25, 2025 1:47 pm I've tried and it works, list_folder is updated. Where is your settings?
