Hello XNView team,
I tried to save more pictures as .raw files, but the result isn't always good. For the picture Penguins.bmp the result is a light blue picture with darker blue lines. Chrysanthemum.bmp output file is so and so. I cannot see the entire picture, just a part of it. I attached you the samples as .jpg files. I won't send you the raw files or the original .bmp files as I noticed the forum doesn't let me to send too large files.
Thank you,
Andrei Miloiu
1.8.8- XNView MP cannot save every picture as .raw file correctly
- Attachments
- Penguins.jpg (121.97 KiB) Viewed 164 times
- Chrysanthemum.jpg (134.99 KiB) Viewed 164 times
Re: 1.8.8- XNView MP cannot save every picture as .raw file correctly
there is no header in .raw file, so you need to have same settings for loading and saving
I understand. Thank you!
