same folder file destination
EZname
Post by EZname »
Hi there,
I've been using XnView for few years and it's a life saver to me. Thanks a lot.
The main use for me in this program is to reduce the image size (and quality) from 2 or 3MB to about 0.250 MB.. Before, when I want to this, I simply right click on the image file that I want , then open with then Xnconvert and it will automatically generate a new file (in the same folder) without asking me.
Now, it keep asking me for the file destination each time. I tried to play with the settings but I could't find that setting...
Any clue?
Thanks in advanced.
Screenshot 2025-04-23 at 7.42.16 AM.png (389.47 KiB) Viewed 320 times
Re: same folder file destination
could you post the dialog?
EZname
Post by EZname »
xnview wrote: Fri Apr 25, 2025 1:44 pm could you post the dialog?
This is what you want?
Screenshot 2025-04-26 at 1.23.54 AM.png (230.05 KiB) Viewed 272 times
'output tab' please
