1.8.8: Extra blank parameter added to command line of programs launched using Open with menu
juozas
Post by juozas »
Subject: 1.8.8: Extra blank parameter added to command line of programs launched using Open with menu
XnView: MP 1.8.8 - 64 bit
OS: Ubuntu Linux 22.04 LTS (64bit)
Launching a program using an open with menu ads an extra parameter in it's command line, triggering an error in some programs. Extra command line parameter is shown when inspecting the Linux proc filesystem for affected external program.
$ xargs -0 -I{} echo \"{}\" < /proc/$(pidof gimp)/cmdline
"/usr/bin/gimp"
"/home/juozas/Paveikslai/image.jpg"
screenshot of configure programs dialog, first command liested above is used in example
Ekrano kopija_2025-04-20_14-34-06.png (37.52 KiB) Viewed 284 times
screenshot of an external program
Ekrano kopija_2025-04-20_14-31-16.png (1.25 MiB) Viewed 284 times
Effect: External program displays an error :bug:
  1. Add an external command using File->Open with->Configure programs menu
  2. Open an image in viewer or have it selected in browser
  3. Use the File->Open with->[program name] menu
Actual behaviour (bug): External program showing an error (e.g. gimp showing error that *current path* is not a regular file) :bug:
Expected behaviour: No extra unneded parameter for external programs, external program does not show an error
Сделано в СССР
Re: 1.8.8: Extra blank parameter added to command line of programs launched using Open with menu
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
juozas
Post by juozas »
I confirm that it's fixed (Tested in 1.9.1, probably fixed in 1.9.0 too)
Сделано в СССР
