«Hidden» settings
Locked
«Hidden» settings
KeyTypeDefaultDescription
[Start]
fixFlickerbooltrueWindows: Fix flicker when app's window is opened
debugint0Debug logs (0 or 2)
[Policy]
NoMenuAllCategoriesint0Visibility of menu item 'Remove from all categories'
setCategorybooltrueVisibility of menu item 'Set category'
settingsbooltrueVisibility of menu item 'Settings'
settingsCatalogbooltrueVisibility of 'Settings>Catalog'
settingsBaseFolderbooltrueVisibility of 'Settings>Catalog - Base folder'
menuHelpbooltrueVisibility of menu 'Help'
[General]
undoMaxint5Maximum number of undo
scanNamestringScan-{Current Date [Y-m-d_H-M-S]}Based name for batch scanning
screenshotNameintScreen-{Current Date [Y-m-d_H-M-S]}Based name for screenshot
wallpaperNameintWallpaper-{Current Date [Y-m-d_H-M]}Based name for wallpaper
expandUNCboolfalseWindows: Expand UNC pathname
useInternalVideoPlayerbooltrueUse internal video player
forceIccConvertboolfalseWhen image is loaded, color profile should be applied
localizedSortCategorybooltrueUse localized sorting for categories
[Browser]
bypassFilterboolfalseOpening a viewer's tab from browser keep current filter
thumbScrollStepint20MacOS: Step for vertical scrolling
folderColor1int255 255 170Colors used for folder thumbnail
folderColor2int255 200 174Colors used for folder thumbnail
folderColor3int197 140 0Colors used for folder thumbnail
folderColor4int250 210 105Colors used for folder thumbnail
folderColor5int172 140 53Colors used for folder thumbnail
toolBar2LinesboolfalseMini toolbar (with field path) always on 2 lines
littleBarVersionint1To use old mini toolbar
positiveRatioint1Image ratio is displayed as positive value
allowCustomOrderint1Allow to rearrange thumbnails in browser by drag&drop
[Appearance]
detailColoredRatingboolfalseDetail mode, use greyed rating
useVideoInfoboolfalseExtract video information in labels
leftInfobooltruePosition of rating/color label
[CatSets]
TopLayoutBarboolfalsePosition for layout settings (category sets)
[Preview]
infoHeaderFlagsarrayexiftoolShow header in metadata panel (exiftool iptc exif xmp)
showAlwaysTabsboolfalseHide empty tab in information panel
[Viewer]
dirtyWhenDisappearboolfalseImage in viewer's tab should detect if file is deleted
keyScrollSpeedint64Scrolling step
pasteKeepRatioboolfalseKeep ratio when pasting from clipboard
scanFilesbooltrueScan the files in the folder of image file
statusLeftInfoboolfalseStatus bar: cursor position on left
maxCharsFilenameint32Status bar: characters count for filename
[Convert]
sortScriptbooltrueSort script list
[Properties]
osDialogboolfalseWindows: Show system properties dialog (Viewer)
[Load]
GIFFullLoadingboolfalseGIF: Load fully file to have number of frames
Locked
