How to disable zoom preview panel
mdeath
Post by mdeath »
whenever we zoom, there always this preview panel on the right bottom
i mark it red
how to remove/disable it?
Re: how to disable zoom preview panel
mdeath wrote: Tue Apr 08, 2025 11:30 am Whenever we zoom, there always this preview panel on the right bottom
Uncheck Tools > Settings... > View -- Show Pan tool ... :D
Yes, it's a pain isn't it, but the option was requested by users, and setting the default to Enabled does aid discoverability, although also raising the question of whether it can be disabled and how to do it. :wink:
mdeath
Post by mdeath »
cday wrote: Tue Apr 08, 2025 11:52 am
hey thanks for the reply.
i don't see show pan tools?
Re: How to disable zoom preview panel
I'm using v1.8.6, so if you are using the latest version v1.8.7 it has obviously been moved, you should I expect be able to find in another View menu.
Too much to hope that it has been deleted... :D
user0 where is it now? :wink:
'Show Pan tool' renamed to 'Show Navigator'
mdeath
Post by mdeath »
user0 wrote: Tue Apr 08, 2025 1:53 pm 'Show Pan tool' renamed to 'Show Navigator'
thanks it works now, the preview disappeared
