Exif changes not being written
reddwarf4ever
Post by reddwarf4ever »
took me ages to find out that the changes i set are not being written to the files, i have the 32 bit version, there is NOT an option to keep original date/time for Embedded metadata, so cant untick it
cant see why such an option exists anyway, but its not there to disable
help please, have version 1.5.5
thanks
Re: Exif changes not being written
Are you able to run the 64-bit version, that may be your only solution depending on when the option you require was introduced?
