How to start XnviewMP on a new install?
artsi
Post by artsi »
New laptop and I want to use 1.87.
All the photos that I want to keep are on external drive and I don't want to have XV scan the laptop drive.
I want only to scan the external drive. How do I setup this before I install and do the first start of xnviewmp?
I know that I can restrict the scan in the settings but that's after the 1st run and the 1st scan.
The reason for not wanting the scans of laptop drive is that xv will create categories from the photos on the latop...
Thanks
Re: How to start XnviewMP on a new install?
artsi wrote: Sat Apr 05, 2025 12:20 am I know that I can restrict the scan in the settings but that's after the 1st run and the 1st scan.
app does not "scan drive" it only scans open folder
even if some Categories have been added you always can delete them all via Categories Management (Browser>Categories pane)
artsi wrote: Sat Apr 05, 2025 12:20 am How do I setup this before I install and do the first start of xnviewmp?
there is no settings file in the package, it appears only after 1st start
so, you either do as above or modify old xnview.ini, eg:
[DB]
folder=C:/excluded1/, C:/excluded2/, C:/excluded1/included1/
folderFlag=0, 0, 1
add some folders into Excluded/Included (Settings>Catalog) and check how it looks in xnview.ini
artsi
Post by artsi »
Perfect exactly what I was looking for.
Thanks
