Hello, I have a problem with 3fd files
Xn view doesn't display the image at the right size even though it recognizes it at the right size.
It should display 11000 px wide but it displays 3500.
Do you know how I can solve this problem?
Thank you very much for your help.
display size wrong 3fr from Hasselblad
Re: display size wrong 3fr from Hasselblad
change 'Camera RAW, use' from 'Embedded preview to 'Full size' in (in Settings>View)
Thank you very much for your reply. I've already done this and it works for images taken from a Nikon Z 9, for example, but for 3FR images taken from hasselblad it still resizes them.
guess you need to share sample file
similar issue with .fff file (850Mb samples) from H6D-400c MS (2018–present)
Multi-Shot technology camera capturing 400-megapixel images by combining four 100-megapixel photos.
here is a link with an example image :
https://www.dropbox.com/scl/fi/a2d3epke ... ssh2g&dl=0
1.8.6 opens your file in full size when you change the setting, as I said above
it works now
thanks you very much
