1.8.6: Open Archives (*.zip etc.) in XnViewMP does not work anymore
jacomo
Post by jacomo »
Version: XnView MP 1.8.6 64 bit
OS: Linux 64bit
Problem:
If you click on an archive file or press Enter, the content is no longer displayed (I have only tested zip files, but it is likely that the other archive files are also affected)
I had a look at the old AppImage versions to find out from which version it stopped working:
The last version where it still works is:
  • XnView_MP-1.5.5.glibc2.17-x86_64.AppImage
The first version where this no longer works:
  • XnView_MP-1.6.0.glibc2.17-x86_64.AppImage
In this context, I noticed that the rating of images within (zip-)archives does not work (in version 1.5.5). But I don't know if this is a bug or if it belongs to the “Suggestions” section.
bye,
jacomo
Re: 1.8.6: Open Archives (*.zip etc.) in XnViewMP does not work anymore
and with the tgz package?
jacomo
Post by jacomo »
xnview wrote: Tue Mar 25, 2025 9:39 am and with the tgz package?
What do you mean exactly? Do you mean XnView_MP-1.8.6-linux-x64.tgz? Or do you mean a plugin? Is the code of tgz and AppImage different? Whatever you want - i can try it some hours later.
abobong
Post by abobong »
I think probably the developer meant to ask me to verify if the same error occurs with the tgz archive, in order to isolate the problem.
Oh well, gotta put in the effort.
jacomo wrote: Tue Mar 25, 2025 2:22 pm What do you mean exactly? Do you mean XnView_MP-1.8.6-linux-x64.tgz? Or do you mean a plugin? Is the code of tgz and AppImage different? Whatever you want - i can try it some hours later.
yes please try the tgz package if it works
jacomo
Post by jacomo »
Hi!
First of all, sorry for the late reply.
I have now tested several versions (under Linux).
Notes:
- Tested with *.zip and *.rar archives
- The test platform was Ubuntu 22.04.5 LTS.
                    | AppImage  |   tgz     |   deb     |
Version 1.00.0      |    ok     |    ok     |           |
Version 1.3.1       |    --(1)  |    ok     |    ok     |
Version 1.4.0       |    ok     |    ok     |           |
Version 1.4.5       |    ok     |    ok     |           |
Version 1.5.0       |    ok     |    ok     |           |
Version 1.5.5       |    ok     |    ok     |    ok     |
Version 1.6.0       |    --(2)  |    --(3)  |    --(3)  |
Version 1.6.5       |    --(2)  |    --(3)  |           |
Version 1.7.0       |    --(2)  |    --(3)  |           |
Version 1.7.2       |    --(2)  |    --(3)  |           |
Version 1.8.0       |    --(2)  |    --(3)  |           |
Version 1.8.7       |    --(2)  |    --(3)  |    --(3)  |
Legend:
ok = Unpacking within XnView is possible, images were displayed
-- = Unpacking within XnViewMP is NOT possible
[empty] = Not tested
(1) Archives could be opened, thumbnails were displayed as placeholders, images could not be displayed
(2) Enter or double-click on the archive does nothing
(3) The linked unpacker is opened (here engrapa)
bye
This problem is supposed to be fixed in XnView MP 1.8.8. Please check and confirm the bug fix here.
