Browser - Categories, Category Sets - add Delete unused, rearrange controls
XnViewMP 1.8.6 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser - Categories, Category Sets pane
  • Categories
    • add 'Delete unused (empty) Categories..'
      command to delete cats that have not assigned to any image (have no records in TagsTree table), eg
      DELETE FROM Tags
      WHERE NOT EXISTS (
          SELECT 1 FROM TagsTree WHERE TagsTree.TagID = Tags.TagID
    • rename 'Clear' to 'Delete'
      imo:
      - Clear - to clear temporary data, eg output list or terminal with cls
      - Remove - to remove data from the list w/o deleting data itself, eg add/remove files to/from the list
      - Delete - to delete original data, eg delete file/metadata or Category from list (as you may not have file with this cat anymore, so it will not be reimported)
  • Category Sets
    - move Layout controls to the bottom
    - move 'Manager..' button to the right and shorten label to '...'
Example
  • DxO
Related
Re: Browser - Categories, Category Sets - add Delete unused, rearrange controls
done in 187
