Layout and change of language
XnViewMP 1.8.6 64Bit Windows 11
HI,
Layout of XnViewMP is not kept when changing language.
Even is you save the configuration (for example : "enregistrer la disposition A" in french), when you restore it in English (restore layout A) you get something corrupted.
Meanwhile, if you get back to the previous language, you can restore the correct layout.
In short, layout are not change of language compatible.
Thanks.
Eric.
HI,
Thanks.
Eric.
Re: Layout and change of language
Yep, me too.
i'm not able to reproduce. what is not correctly restored?
After choosing my language, I also changed my layout to a different one than the default. I saved, I left, and I use this layout all the time. But to make savescreen, I changed language to English, and then after restart the application, I have the default layout, different from me choice. After returning to my native language, the layout returned to me choice.
This bug is very old.
I can't find this file. There is no that file in .ini folder.
I use Win11.
Hi Pierre,
I'm using Layout 1 for the test.
PS : I rename the layout1.dat in layout.dat.png because the newsgroup don't accept ".dat" file !
Thanks.
Eric.
Thanks.
Eric.
- Attachments
- XnView Layout 1 - English.png (649.91 KiB) Viewed 589 times
- XnView Layout 1 - French.png (694.02 KiB) Viewed 589 times
Pierre,
Strange : I'm unable to attach the layout.dat even if I rename it.
OK.
I open layout1.dat in Notepad++ and do a screen capture .
You find also two others screen capture : the layout1 in french language and the layout1 in english language. You notice the difference.
If I get back to french, I get also the right layout.
Eric.
Eric.
- Attachments
- layout1.png (43.8 KiB) Viewed 584 times
This is my ini folder:
Directory: C:\Users\jwarc\AppData\Roaming\XnViewMP
Mode LastWriteTime Length Name
d----- 23.02.2024 21:24 AddOns
-a---- 22.02.2025 14:36 0 autocorrect.txt
-a---- 14.02.2025 20:56 13532 batch_convert_log.txt
-a---- 15.02.2024 20:02 431 bookmark.ini
-a---- 08.10.2024 22:48 3040 CropSize.xml
-a---- 08.04.2024 23:30 752 default.bar
-a---- 08.04.2024 23:30 6194 default.keys
-a---- 27.10.2022 17:32 713 iptc.ini
-a---- 25.03.2025 20:38 342294528 Thumb.db
-a---- 04.02.2025 21:52 2471 Xmp.ini
-a---- 25.03.2025 20:48 5144576 XnView.db
-a---- 25.03.2025 20:54 52066 xnview.ini
Files from this folder was sanding without too big Thumb.db.
