XnView Classic 2.52.1
Dear user,
XnView Classic 2.52.1 for Windows is available. Versions are available on the normal XnView Download page.
Please note that the XnView Download page offers packages with German/French Setup and German/French Online help.
Direct links to the English Standard version are:
https://download.xnview.com/XnView-win.exe (English Setup, Multi language)
https://download.xnview.com/XnView-win.zip (ZIP file, Multi language)
XnView Shell Extension 32bits:
https://download.xnview.com/XnShellEx.exe
https://download.xnview.com/XnShellEx.zip
XnView Shell Extension 64bits:
https://download.xnview.com/XnShellEx64.exe
https://download.xnview.com/XnShellEx64.zip
SHA256:
XnView-win.exe: 375082C9A9F9DBE0C1AE50CBC99DE9EACFBA9C0C59D522BB9303FF33566A2C0D
XnView-win.zip: 3604AE83700E0C80E9732F3D1087D1B36F90BC691C4D1BB43F7E71AC324DFB67
XnView-win-full.exe: CCEC21AB757E3FB1228DE2C3D0CB4472EB816A74405AE63D2F077BF3088B5DDD
XnView-win-full.zip: C925EE8F67BA45C8F893E3E033A310C947B2975CA29EB2BA63C78A7B96B57F4B
XnView-win-small.exe: A59D2E9829F1C0ACFE0A7BE09097767FB24F45E2C59EAC061E635716631A7734
XnView-win-small.zip: EFCAB253EC2D389C9D0DB83AEF565ABD5C6FD30A065BA0537A508D3F40BEC649
____ 2.52.1 Changelog
* Libwebp 1.5.0
* Ghostscipt 10.05
* JPEG 2000 - encoding
____ 2.52.0 Changelog
* Old plugins removed from package
* NConvert: multipage and delete option
____ 2.51.7 Changelog
* GIF print - viewtopic.php?f=36&t=47348
* CVE - Thanks to Matteo Marini
____ 2.51.6 Changelog
* ICC
* TIFF CVE - Thanks To Eugene Lim
* CVE - Thanks to Junsoo Lee
* NConvert: Clear - viewtopic.php?f=57&t=46797
____ 2.51.5 Changelog
* HEIC not loaded
* LibWebP CVE
____ 2.51.4 Changelog
* TIFF crash
* NConvert: Bad output for TIFF LZW+Predict
* NConvert: Filelist - viewtopic.php?f=57&t=46034
____ 2.51.3 Changelog
* CVE - Thanks to Seyit Sigirci
* NConvert: HEIC (x64) - viewtopic.php?f=57&t=44026
* NConvert: TIFF 16 bits output with Predictor - viewtopic.php?f=57&t=44869
* NConvert: -keepcspace & big image - viewtopic.php?f=57&t=44789
____ 2.51.2 Changelog
* Export & extension missing - viewtopic.php?f=36&t=43430
* Argument in utf8 - viewtopic.php?f=36&t=44014
* Susie plugin - viewtopic.php?f=36&t=43887
* NConvert: longest/shortest & mm - viewtopic.php?f=57&t=44670
* NConvert: -recurse - viewtopic.php?f=57&t=43854
____ 2.51.1 Changelog
* CVE by Xu Peng from UCAS
* Minor fix
* NConvert x64 : JPEGXL & AVIF - viewtopic.php?f=57&t=43732
____ 2.51.0 Changelog
* WebP in Slideshow 'add folder' - viewtopic.php?f=36&t=42755
* QOI read support
* WebP 1.2.2
* NConvert: AVIF support - viewtopic.php?f=57&t=43096
* NConvert: Canvas resize & CMYK - viewtopic.php?f=57&t=42022
____ 2.50.4 Changelog
* TIFF crash
____ 2.50.3 Changelog
* Rotate dialog & show grid - viewtopic.php?f=36&t=42496
* Canvas resize on 1bit picture - viewtopic.php?f=36&t=39569
* FITS better support
* NConvert (Windows): Recurse support - viewtopic.php?f=57&t=42626
eg.: nconvert -o output/% folder
* NConvert: $DateModified - viewtopic.php?p=169286
* NConvert: Multipage output filename - viewtopic.php?f=57&t=42584
____ 2.50.2 Changelog
* Labels & tooltips can crash
* PNG crash
____ 2.50.1 Changelog
* Browser size not restored - viewtopic.php?f=36&t=42207
* Dialog always on Screen #1 - viewtopic.php?f=35&t=42147
* Context icon - viewtopic.php?f=34&t=42232
* NConvert: multiple -canvas & bgcolor
* NConvert: -jpegtrans - viewtopic.php?f=36&t=41826
* NConvert: -canvas longest 220mm - viewtopic.php?f=57&t=41812
* NConvert: jpegtrans exif & keepfiledate - viewtopic.php?f=57&t=42203
____ 2.50 Changelog
* APNG crash - viewtopic.php?f=36&t=41803
* JPEGXR RGB10
* CR2 orientation problem
* Ghostscript 9.54
* Recoil
* GEM vulnerability - Thanks to Michael Heinzl
* NConvert: -use_org_quality problem
* jpegtrans not written for NConvert - viewtopic.php?f=36&t=41826
* NConvert: -text_font name percent - viewtopic.php?f=57&t=41811
* NConvert: -canvas shortest/longest - viewtopic.php?f=57&t=41812
____ 2.49.5 Changelog
* Ghostscript detection
* TIFF - viewtopic.php?f=35&t=41136
* HEIF plugin - viewtopic.php?f=36&t=41104
* Old versions of ghostscript not recognized
* NConvert: -use_org_quality - viewtopic.php?f=57&t=41397
* NConvert: multiple text lines - viewtopic.php?f=57&t=41358
____ 2.49.4 Changelog
* Ghostscript 9.53.x
* GPS & file date - viewtopic.php?f=56&t=40971
* TIFF Security vulnerability (Thanks to Michael Heinzl)
* NConvert: -levels2 - viewtopic.php?f=57&t=40490
* NConvert: -resize supports cm/mm/inches
* NConvert: -autodeskew fixed
* NConvert: -noholder to disable %$ chars - viewtopic.php?f=57&t=40820
____ 2.49.3 Changelog
* Convert 16 to 256 colors - viewtopic.php?f=36&t=39421
* Disable ESC to close tabs - viewtopic.php?f=35&t=17078
[General] EscToCloseView=0
* Select file from search results & switching mode - viewtopic.php?f=34&t=40063
* Title empty when recurse - viewtopic.php?f=36&t=39979
* Resize - viewtopic.php?f=35&t=40248
* Slideshow: Order of files - viewtopic.php?f=56&t=40087
* Fortis Mag fix
* NConvert: -wmsize watermark percent size - viewtopic.php?f=57&t=38754
* NConvert: canvas size in inches/cm/mm - viewtopic.php?f=57&t=39361
* NConvert: replace_color - viewtopic.php?f=57&t=39769
* NConvert: -temperature added
____ 2.49.2 Changelog
* Problem with Ghostscript 9.50
* PDF font problem - viewtopic.php?f=36&t=39662
* CR3 - viewtopic.php?f=35&t=39478
* .sld must use 'Recurse' setting - viewtopic.php?f=35&t=39330
* GIF loop - viewtopic.php?f=36&t=31689
* PAM CMYK
____ 2.49.1 Changelog
* TIFF 16bits greyscale
____ 2.49 Changelog
* SQLite 3.29.0
* NConvert: greater_than/less_than condition - viewtopic.php?f=57&t=39147
* PSD: Error when writing metadata - viewtopic.php?f=57&t=39137
* Export - Problem with RGBA - viewtopic.php?f=36&t=39044
* Capture - viewtopic.php?f=36&t=38934
* Left/Right F11 to open fullscreen on Left/Right monitor
* Create multi file & folder with '.' - viewtopic.php?f=36&t=39008
* # to comment line in .sld file
* Multipage create: Check if output filename exists
* Slideshow crash when using animated GIF - viewtopic.php?f=36&t=38902
* XIM format import added
* Change timestamp must not use 12h format - viewtopic.php?f=36&t=38702
* GIF not played correctly in Slideshow - viewtopic.php?f=34&t=38303
* CVE - https://github.com/apriorit/pentesting/ ... ugs/xnview
* NConvert: -unsharp
* NConvert: -exposure - viewtopic.php?f=57&t=39136
* NConvert: -colorize h l s
* NConvert: Remove EXIF orientation -exif_rotation - viewtopic.php?f=57&t=38648
* [Rename]/TemplateStart, position of number in template - viewtopic.php?f=34&t=38568
* CVE-2019-12151
* ShellEx: 'Convert...' & input fields
Radim
Re: XnView Classic 2.52.1
Post by Radim »
There is an update of CAD Soft plugin (03/2025):
http://cadsofttools.com/download/cs_svg.zip
Radim
Post by Radim »
I have problems to view SVG with this new SVG plugin, trial:
http://cadsofttools.com/products/plugin ... -programs/
XnView froze, and not show SVG... :x
Dan Harkless
Post by Dan Harkless »
On the main website, the SHA256 sums don't appear to have been updated for 2.52.1. On https://www.xnview.com/update_xnviewclassic.php, it appears to be the checksums from 2.52.0, and I don't know where the sums on https://www.xnview.com/en/xnview/ are from. The checksums at the top of this thread do match what I downloaded, however. Thank you.
