Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Browser - metadata
"Update Catalog from Files" and "Update Files from Catalog" commands only work with selected file(s),
and do nothing when no file(s)/folder(s) is selected.
However, both commands are always enabled.
- clarify commands behavior
depending on the desired behavior when no file(s)/folder(s) selected, either:- disable commands
OR
- update functionality to apply command to all files in current folder and subfolders if any exist
- disable commands
Related
- issues
- todo -
1.8.3 - browser - categories - 'Hide assigned categories' has no effect
1.4.4 - viewer - categories - not possible to modify categories via properties
- fixed -
1.5.0 - browser - category sets - no duplicate check (1.5.0)
1.4.4 - browser - categories - inconsistency in Category creation routine (1.5.0)
- suggestions
Browser - Categories - clean up menu
Browser - Categories - add counter and sorting
Browser - Category Sets - formatting and management
Browser - Category Sets - Assigned, Suggested - improve update trigger
Browser - metadata - Update catalog/file commands - clarify behavior (current post)
Categories - menu - add Uncategorized and Sets
Categories - shortcut - show in Set Category menu
Categories - shortcut - add unassign functionality
Shortcuts - general - add commands to increase/decrease rating/color label
Browser - favourites - allow drag to root level
Browser - categories - allow drag to root level
- done -
Browser - Categories, Category Sets - add Delete unused, rearrange controls (1.8.7)
Tag - merge Tag / Untag (1.7.0)
