Batch Converter : meta-data slow
meteorquake
Post by meteorquake »
A bug, in the sense of slower than expected.
If I drag 1000 JPG files (that originally came from a camera, now on an SSD) into the batch converter, in the input files section before you action anything it reads through and populates the meta data very slowly (eg 2-3 files per sec, I've not measured it exactly), as if it is reading the whole file rather than only the metadata. This means you have to wait for ages to sort on the relevant metadata. The SSD is not the fastest but shouldn't be this slow - void's Everything reads the meta data much much faster.
I would expect it would just need to read a partial amount of data and so should be much faster. Is this something that can be improved on, or something I can do at the user end to improve the speed? Primarily I am (in this particular case) sorting on dimensions or aspect ratio...
Cheers, David
Re: Batch Converter : meta-data slow
which mode do you use for file list?
meteorquake
Hmmm I think it speeds up a lot if I remove all the columns and add only the ones I want. I'm surprised at the difference that makes - I'd have expected a bit, just not quite so much.
So perhaps the other way of looking at it is, are there too many default columns in the Batch Converter?
Perhaps it should have a minimal number and when it is blank before anything added, it could provide a little help in the blank area such as "Right-click headings to add more columns" which disappears on adding items, or something similar such as an extra blank column header that indicates to right-click for more, even if just three dots or "+".
d
if you use 'List'?
