How to make jpg open on screen and not in task bar?
slbeard
Post by slbeard »
When I click on a jpg, an icon appears in my task bar and then I have to click the icon in the task bar before the jpg appears on my computer screen How can I fix this so that when I click on a jpg, it open directly on my computer screen. I find this 2 step process VERY annoying. Please help
Re: How to make jpg open on screen and not in task bar?
windows 10?
slbeard
Post by slbeard »
Yes. I am using Windows 10
could you send us your xnview.ini
slbeard
Post by slbeard »
Is this what you requested. It is very long but is what appeared when I clicked on ini. I appreciate your help.
[removed]
slbeard wrote: Sat Mar 22, 2025 2:26 pm Is this what you requested. It is very long but is what appeared when I clicked on ini. I appreciate your help.
with your .ini, i'm not able to reproduce. the picture is opened in XnView, and shown
