1.8.6 - formats - DICOM - read issues
XnViewMP 1.8.6 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Formats - DICOM - read
some .DCM files open with errors or not open at all
(eg ImageGlass has no issues opening sample files)
DICOM_samples.zip
(902.05 KiB) Downloaded 54 times
Re: 1.8.6 - formats - DICOM - read issues
user0 wrote: Tue Mar 18, 2025 4:56 pm XnViewMP 1.8.6 64bit
some .DCM files cannot be opened or opened with errors
some .DCM files cannot be opened or opened without errors? :wink:
(first sample can't be loaded, jpeg2000 compression is not supported)
This problem is supposed to be fixed in XnView MP 1.9.0. Please check and confirm the bug fix here.
fixed in 190
