Scaling by width or height alone is not supported
Cople
Post by Cople »
It is supported in XnConvert, but the exported NConvert command does not achieve the same effect; NConvert only supports setting width and height at the same time.
Re: Scaling by width or height alone is not supported
yes you use 0
Cople
Post by Cople »
xnview wrote: Wed Mar 19, 2025 4:16 pmyes you use 0
thanks. it should be added to the help documentation
