Hiding tabs
ellos
Hiding tabs
Post by ellos »
I would like to hide the tabs, the ones indicated with arrows in the attached screenshot. Doing it through the menu > View > Tab > Show only hides it for the particular asset that is being viewed and doesn't stick.
Is there a way to hide them permanently?
Re: Hiding tabs
"menu > View > Tab > Show" doesnt work?
ellos
Re: Hiding tabs
Post by ellos »
It works only once for the specific item that is currently open, for all others it doesn't work.
See the screenshot here, the option is unchecked yet the tabs show.
https://imgur.com/a/8GdVllx
Re: Hiding tabs
i can't reproduce with 1.8.6, could you send me your xnview.ini?
ellos
Re: Hiding tabs
Post by ellos »
Where would I find xnview.ini on Mac?
Re: Hiding tabs
Settings>Integration - open config location
