XnConvert unable to do any actions
vanderzee
Post by vanderzee »
Version 1.104.0
it simply doesnt do any actions assignes, especially to resize images, they just stay the same size, regardless of source of file type, it doesnt wotk at all (tried all different options)
BUT only if i want to keep the same format or "same as original", if i choose another format (for example from jpg to png) it workes
but it worked before the update
using windows 10
suggestions?
Re: XnConvert unable to do any actions
please post some screenshots? from jpeg? into jpeg?
vanderzee
Post by vanderzee »
xnview wrote: Sun Mar 16, 2025 7:30 am please post some screenshots? from jpeg? into jpeg?
it cannot be same format - like png to png, jpg to jpg etc.
once you click OK xnconvert closes quickly without doing anything (doesnt matter which action, it does not work at all)
have to change the format, doesnt matter which, like jpg->png, jph->bmp, png->jpg then it does the action i asked for
thanks
2025-03-16 11_30_03-XnConvert.jpg (76.24 KiB) Viewed 368 times
2025-03-16 11_26_06-XnConvert.jpg (82.28 KiB) Viewed 368 times
2025-03-16 11_25_57-XnConvert.jpg (87.51 KiB) Viewed 368 times
i can't reproduce, please send us the xnconvert.ini?
vanderzee wrote: Sun Mar 16, 2025 2:30 pm it cannot be same format - like png to png, jpg to jpg etc.
check your settings:
- if output file exists [skip]
- ☑ Exit after conversion
- folder - source
- filename - same as original
vanderzee
Post by vanderzee »
please send me a jpeg file used
