1.8.6 - XnViewMP crashes in browser view with jpeg-xl files
masterjp
Post by masterjp »
I have many jpeg files transcoded to Jpegl-XL format.
I have a directory with up to 200 jpeg xl files.
If I use the browser window and open the directory,
XnViewMP try to scan the files and generate thumbnails of the jxl files.
During this process I double click on a jpeg xl file to open it.
Then XnViewMP sometimes crashes.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
abobong
Re: 1.8.6 - XnViewMP crashes in browser view with jpeg-xl files
Post by abobong »
XnViewMP's thumbnail generation is very unstable, even beyond JPEG XL. Opening files after deletion inevitably crashes the program. So, I deliberately avoid any file interaction during thumbnail creation.
My apologies if this is an isolated bug.
masterjp
Post by masterjp »
Nice to hear, I am not the only one who has this problem. Okay, I will try to do nothing until the thumbnails are generated.
abobong wrote: Tue Mar 18, 2025 12:35 pm XnViewMP's thumbnail generation is very unstable, even beyond JPEG XL. Opening files after deletion inevitably crashes the program. So, I deliberately avoid any file interaction during thumbnail creation.
do you have a way to reproduce?
masterjp wrote: Tue Mar 11, 2025 7:52 pm Then XnViewMP sometimes crashes.
do you have sent the minidump with crash dialog?
