1.8.6 - batch conversion - presets do not save jpeg-li compression quality
masterjp
Post by masterjp »
In Version 1.8.5 or 1.8.6 of XnviewMP you changed program parts of the JPEG components and better support the new JPEG-LI compression.
In batch conversion I often use the JPEG-LI encoder and in previous versions it was possible to save the compression quality settings in a presets!
In the current version the jpeg-li quality setting does not get saved. It would be nice, if xnviewmp will save the settings in the presets.
PC: Intel 8700k + Asus Z370-F + 16 GB RAM G.Skill + Asus RTX 3050 OC + Samsung SSD
OS: Windows 10 Pro 64bit 22H2 |
GFX: XnViewMP 1.8.7 | XN-View 2.52.0 | XnConvert 1.104.0 | Adobe Photoshop Elements 2024 | Elements XXL 11 | Paint.Net 5.1.7
Re: 1.8.6 - batch conversion - presets do not save jpeg-li compression quality
there are 2 options in formats:
- JPG - JPEG / JIFF (with 'Use JPEG-li' checkbox)
- JPG - JPEG-LI
shouldn't 2nd be removed as redundant ?
masterjp
Post by masterjp »
I usually use the JPG - JPG-LI Format in the presets and it would be useful, if the presets will save the compression level and settings of the dialog window. Thank you. For the normal JPEG/JIFF setting it works.
Stock
Post by Stock »
XnViewMP 1.8.7 correctly saves jpegli parameters into .xbs now.
However, XnConvert 1.104 is still broken.
