[v1.104] JPEG decoding with dithering
Moderator & Librarian
  1. Go to SettingsLoad format settings…Read.
  2. Set DCT to Floating.
  3. Set Dithering to None.
  4. Convert a JPEG to PNG.
  5. Repeat the conversion with Dithering = Ordered.
  6. Repeat the conversion with Dithering = Floyd-Steinberg.
The resulting PNGs are identical :bug:
Xn User
Re: [v1.104] JPEG decoding with dithering
Post by Xn User »
Which method compression in JPEG file was be used ? This very need for report , I mean what 1x1 1x1 1x1 or 1x2 1x1 1x1 or 2x2 1x1 1x1 )
And test was be do with classic JPEG compression methods or JPEG LI compression methods ?
Encoder: libjpeg
Chroma subsampling: 4:2:0 (2×2,1×1,1×1)
XnTriq wrote: Mon Mar 10, 2025 2:30 am testorig.jpg
Encoder: libjpeg
if i check the code of libjpeg, it seems that dithering is only used when quantize with colormap :(
Xn User
Post by Xn User »
Right , Dithering must be do use only for 1x2 1x1 1x1 or 2x1 1x1 1x1 or 2x2 1x1 1x1 , for 1x1 1x1 1x1 dithering not need use )
I also asked in JPEGLi https://github.com/libjxl/libjxl/issues/4146 , you can see what XnView MP and ACDSee Pro 5.0 with IDE_ACDstd 5.0.56.0000 reading file with differ , in result XnView MP with Floyd-Steinberg colors a little rude if compare with ACDSee Pro , I see rude gradients
Xn User
Post by Xn User »
Please , add all this algorithms https://surma.dev/things/ditherpunk/ and will be learn which is better
In the end will better if this algoritms will be apply optionaly to all lossy or images with less colors
this for testing methods of dithering https://surma.dev/lab/ditherpunk/lab.html
