XnConvert 1.104
Locked
XnConvert 1.104
XnConvert (XnView batch convert as multi-platform standalone program) is available.
You can download XnConvert here
Windows x64 Setup
Windows x64 ZIP
MacOSX x64 DMG
Linux x64 TGZ
Linux x64 DEB
Linux x64 App2Image
Linux x64 Flatpak
MacOS APP Store
You can use
XnConvert file1 file3 file3
or
XnConvert @filelist
Re: XnConvert 1.104
xnview wrote: Mon Mar 03, 2025 10:13 am You can download XnConvert here
Linux x64 Flatpak
Flatpak current download is 1.99, several version ago... :wink:
dinkblam
Re: XnConvert 1.104
Post by dinkblam »
the "MacOSX x64 DMG" download link is offline ("404 Not Found")
Re: XnConvert 1.104
dinkblam wrote: Mon Mar 03, 2025 9:03 pm the "MacOSX x64 DMG" download link is offline ("404 Not Found")
it's fixed
UriF
Re: XnConvert 1.104
Post by UriF »
I apologize for a possibly stupid questions
1. I don't see a change log
2. This version is not posted at the oficial web site but only on forum (is it stands for that it i process of fixing?)
Thank you in advance
sopa
Re: XnConvert 1.104
Post by sopa »
Hello, I'm reaching out here because I have a question. I usually use xnconvert to compress .avif files. I use version 1.95 for this because the parameters for compressing avif files have changed in the current versions. My question is why the new versions are not as efficient for .avif files like 1.95, I have done multiple tests between both versions and have checked the quality of the images. it's true that compressing in 1.95 is not faster than new versions. From a 20MB PNG, on version 1.95 a size ranging from 500kb-740kb and the quality practically similar to the original. In contrast, for the newer versions, with a visual quality like 1.95, the file size tends to range from 2MB-3MB for the same speed. Compressing at very low speed on newer versions, I have managed to reach 1MB, but it takes 3 times longer on my PC. My question is whether this fact is being considered, or if there are plans to optimize it, because i have to have two xnconverter versions, one updated and the 1.95 specifically for avif.
By the way, I appreciate that xnconverter is freeware, it has been very useful to me and does a spectacular job, thank you very much.
Locked
