Windows Scale
RainerHH
Windows Scale
Post by RainerHH »
is XnView not scalable?
I have set Windows Scale to 200% on my 4K monitor.
The internal XnView windows and the images are not enlarged!
Re: Windows Scale
win 10?
Re: Windows Scale
RainerHH wrote: Sat Mar 01, 2025 5:16 pm I have set Windows Scale to 200% on my 4K monitor.
this is correct default behavior
check 'Zoom on HiDPI screen: 1 image pixel equals 1 screen pixel' in Settings > View
to have it other way around
RainerHH
Re: Windows Scale
Post by RainerHH »
Yes Windows 10
that can't be, the internal windows are barely readable!
RainerHH
Re: Windows Scale
Post by RainerHH »
Nobody understands that!
I had the same problem with pop-up windows in Windows Explorer. @moinmoin in the Deskmodder forum advised me to try manual Windows scaling, e.g. to 205%. Lo and behold, the problem was gone! I then went back to 200% and the problem is gone.
Now here's the thing: the problem in XNView is also gone!
