In the Batch Convert actions, it's good to shrink down common actions to a heading so they don't create a lot of clutter but can just be ticked on and off.
Some of the actions however have the same headings - you might have a 50% resize and a 75% resize and they are currently all just called "Resize".
* It would be ideal if for each action the user can give a custom title which when entered is used for the action headline title instead of the action name. So instead of Resize the user might put "Resize 75%". Perhaps there could be a box for the title or more simply the ability to right-click the existing headline title, and have a popup to enter a specific one.
Cheers, David
Batch Convert : User-entered action headline titles
