1.86 Display of Batch convert Output tab PDF save quality options
In Batch convert, on the Output tab, the Format Settings... save options on the PDF tab, display for Grayscale and Color save options a Quality setting window, see the following screenshot:
First issue: The display of the value entered is truncated;
Second issue: What is that setting when saving to a PDF file? The loaded file is a PNG, so if it represents the compression at which the PNG is to be saved in the PDF, the format is not displayed in the usual 0 to 9 scale. Tested in 1.8.6, similar in 1.83.
And a third issue: Why was I able to make that screenshot, when normally I can't capture an open dialog: user0? :wink:
Re: 1.86 Display of Batch convert Output tab PDF save quality options
cday wrote: Sat Feb 22, 2025 5:10 pm Second issue: What is that setting when saving to a PDF file? The loaded file is a PNG, so if it represents the compression at which the PNG is to be saved in the PDF, the format is not displayed in the usual 0 to 9 scale. Tested in 1.8.6, similar in 1.83.
its for JPEG option in both comboboxes
viewtopic.php?f=62&t=44010
user0 wrote: Sat Feb 22, 2025 6:27 pm
So previously reported but not amended yet, there is a limit to what one developer can reasonably do quickly.
That leaves the first issue, that the display of the value entered is truncated.
And comment on the third issue welcome, I have for some time been puzzled that screenshots of open dialogs weren't possible, when I recall making them regularly before.
cday wrote: Sat Feb 22, 2025 5:10 pm And a third issue: Why was I able to make that screenshot, when normally I can't capture an open dialog: user0? :wink:
with XnViewMP Capture? don't know )
I use printscreen key or windows Snipping tool for screenshots
user0 wrote: Sat Feb 22, 2025 7:05 pm
In Linux Mint I use the printscreen key, but other methods that I tried briefly also don't work... :?:
