There are many folders, in each one you need to rename the files, but the numbering in each folder should start from 1.
Is it possible to do this somehow?
Now, according to template {Folder name}_###, it turns out that the numbering is common for all folders.
now:
Folder 1
FolderName_001
FolderName_002
Folder 2
FolderName_003
FolderName_004
Folder 3
FolderName_005
FolderName_006
Need:
Folder 1
FolderName_001
FolderName_002
Folder 2
FolderName_001
FolderName_002
Folder 3
FolderName_001
FolderName_002
Renaming files in multiple folders template
