Viewer - navigator - add highlight
XnViewMP 1.8.6 64bit
Windows11 (24H2), display resolution 3840x2160, win scaling 150%
Viewer - navigator
its difficult to find zoom rectangle in Navigator as it blends with bright image due to its narrow border
also there is no click-to-pan/zoom functionality in Navigator (like "☑ click-zooming" in ACDSee), you have to drag zoom rectangle
  • add highlight to navigator (like in ACDSee)
  • (optional) rename
    Show Pan tool → Show Navigator (in Settings>View)
    (like in adobe apps and ACDSee [actually it uses both names])
Example
Related
tajinoxn
Re: Viewer - navigator - add highlight
Post by tajinoxn »
Good suggestion, I personally would prefer Lightroom's implementation, neutral and less obtrusive without dimming down the rest of the image.
done in 187
